TwinTurbo.NET: Nissan 300ZX forum - hmmm... try back later?
Subject hmmm... try back later?
Posted by FuerGrissa on September 08, 2008 at 6:27 PM
  This message has been viewed 83 times.
In Reply To site wont work posted by Z_Freak24 on September 08, 2008 at 06:05 PM
Message otherwise follow some of the vac lines that are hooked up to determine if its the AIV or the EGR solenoid then I can try to help you from memory.
Somone correct me if I'm wrong but I believe its
AIV:
Top port - Connectsx to a nipple on the balance tube
middle port - to the AIV ( I believe through the upper hard pipe galley on the side of the upper plenum)
Bottem port - to the top port on the EGR solenoid
EGR:
Top port - From the bottem port on AIV solenoid
Middle port - To the EGR on the back of the moter
Bottem port - connects to the lower hard pipe galley on the side of upper plenum and then to the nipple on the lower passengerside IC pipe, or possibly to the up pipe off the turbo.
